Xperia C won't fully charge
loupatrice
Hi guys. i just bought my Xperia C yesterday and when I charged it, I waited for like 3-4 hours and when I saw the green light (means fully charge) i saw its only at 99%. Im confused and worried, Help?
Tags (4)
9 REPLIES 9
profile.country.RO.title
_alexdon_
The green light will be on from 90%.After that,you will see in settings-about phone-status if the phone is completely charged.
alexdon
andrews
I have the same problem - phone can continue charging in 99% for about a 30 minutes minimum and more often it stays in 99% charge level with plugged in native charger at all! The charge cycle (Settings>Power management>Battery) does not even start a new one! Why?
_alexdon_
Not always when it reaches 100% it will be full charged,sometime it needs to stay some time there.
alexdon
andrews
It almost never reaches 100%. Furthermore, as I already wrote - new charge cycle even does not start (Settings>Power management>Battery). All phones that I previously had, charged to 100%. It is not a normal behavior to stick in 99%.
_alexdon_
This only happens with a single charger?
alexdon
andrews
With any charger and also when charging from PC.
_alexdon_
You should have the phone checked,maybe the battery is causing problems.
alexdon
BarbaraBR
I'm from Brazil I'm having the same problem I sent my phone to the authorized service center 3 times, but it came back with the same problem. Don't know what to do
Om40
well i have same problem here with z3 that happened twice to me it stayed on 99% for more than 30 mins
