Xperia C charging issue
Gagan20
I bought brand new Xperia C last week and I am facing a serious problem with my phone.
I plug the phone to charge and it charges my phone from 38% to 70% in around 2 hours (which might be correct for a 2400mah battery) but after then suddenly it charges my phone from approx 702% - 100% within 5minutes which is weired.
I charged my phone twice (started charging phone again from 30%) and faced the same issue.
I am pretty satisfied with the performance of the device but I am afraid of this weired problem.
What should I do?
25 REPLIES 25
profile.country.RO.title
_alexdon_
Download sony update service and repair your device:
alexdon
nikhil69
I m also facing battery issues...wen I charge d phone wen it to 83 % ,within 5 mins it reaches to 100%... n while using phone wen battery reaches to 32% it reaches to 13% within 5 mins...how can dis problem be solved???
_alexdon_
Boot your phone in safe mode,see if the same occurs:
alexdon
WOLOLO2Android
This is currently happening to all owners of the Xperia C. Sony has addressed this and is currently working on a fix to this in the next firmware update.
nikhil69
alexdon...I tried wat u said but itz of no use... still problem persists...is Sony noticed this problem??? if yes what is the solution???
_alexdon_
I do not know,I am not working for sony.You could try and contact xperia care:
alexdon
gioaustin
Do some charging cycles drain ur bat before charging
nikhil69
Austin I have tried dat...
ashleyevans
i put my phone on charging overnight..still it showed18% battery in the morning.. is something wrong with my cellphone.. if yes den can i change it as my cellphone is under warranty... also dis is the first tym it happened...
_alexdon_
