Xperia Arc won't charge from wall socket
jumax9
When connected to PC it charges without any problem, however, when pluged to the wall socket it doesn't work (it doesn't matter if it's on or off, it won't charge).
I happen to have another Xperia Arc (lucky me) so I know the problem is with my phone because the other one works (even using the same wall socket). This is not actually troublesome since I can charge using the PC but it's something weird I'd like to fix (or, at least, know why it happens)
4 REPLIES 4
have you try the obvious a different wall socket? and a different usb cable?
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
jumax9
Yes, of course, I tried with the ones from the other phone I have (and I tried the other phone with mine, it worked too)
you could repair your phone with SUS to narrow down the issue
Update Service (SUS)
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
jumax9
it's necessary?  I have a custom rom and if I'm not mistaken, I'll lose my data if I do that (and I've got the custom rom since past May or so, it shouldn't be the reason why it's not charging because the problem brand-2013-new :smileysilly:).
Anyway, if there's no other way/solution I'll do it.
