Xperia Arc SD card problem
Vipinrahul
Am facing a big issue now.this morning  the phone got stuck suddenly and could not do nothing. even pressing the power button did not help. so i had to remove battery manually and restart the phone. since then the phone is not reading the memory card and says unmounted. tried removing it and inserted it many times and it is still not getting detected. have so many things in the card. tried the card in another phone and a card reader and it is still not getting detected. an adnroid app was being updtaed and after this the Android Booster app was scanning it as usual. it is during this scan that the phone hung up and was frozen. any suggestions? i have everything in the card and i need it to work or atlease retreive the data. the issue is the card is not being detected by any device...........help please.............
16 REPLIES 16
Balakrishnan
hai,
use pc companion and repair it .
Hi there, I've posted a similiar thread just 2 days ago. Do look it up and see how it got solved.
Vipinrahul
Hey! I can use PC COMPANION to repair only the phone. It reinstalls the software.I have a SD card issue frined. How do if fix this? It is not being detected by any other phone or device.
Vipinrahul
Hi! I already read your post earlier. But your issue was easily fixed right? Mine is a but tough. The card is not being recognized by any device. Tried another mobile and card reader and same proble.
just remove the SD card, repair the phone with either PCC or Update Service and then put the SD card back on your phone, see if that works. (just try it)
here is SUS
Update Service (SUS)
if the SD card it's NOT recognize by any other phone and/or computer, then most likely your SD card its dead sorry, it happens.
Vipinrahul
Ok friend. But that will delete all dat on phone right? I don't have backup? Can i backup phone contents?
there are myriad options to backup your phone, try this
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
http://www.fjsoft.at/en/
sync your contacts with google
Contacts
open your phonebook
on your computer
also
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
SMS/MMS/Call Logs
Install "backup SMS+" to back up your SMS, MMS and Call Logs  to your Gmail
or just SMS use
"backup & restore SMS"
