Xperia Arc S (LT18i) problem
Davezy
Hey there Sony / Sony Ericcson users! I have a problem, a pretty big one. So last night I was browsing facebook when my phone froze, so I removed the battery and put it back in.
Then I tried to boot it again and I only get a half a second vibration then nothing happens. If I want to get that vibration again I need to remove and put the battery back on.
I have tried everything, all the keys combinations (I think), and trying to update the software with Sony's tool, it says its up to date .. please help me, I really want to get the phone fixed, any help would be very appreciated! Thanks a lot.
Dave.
9 REPLIES 9
There isn't an option to Install the current firmware? (bottom right of SUS)
Davezy
Where is that exactly, what step, if I may ask
Install SUS > restart your PC > run SUS > turn off your phone > follow the steps > it will tell you that y ou have the latest update available > on the bottom right it should give you an option to install it
if that doesn't work you have 2 options
1) take it to a Sony repair center
or
2) use flashtool
How to manually update, downgrade, root 2011 Xperias
http://talk.sonymobile.com/thread/38251
Don't forget to give Kudos
shihstouch
Enthusiast
I hope yours is ICS, this happens because of low memory.
All you need to repair with SUS as mentioned by uliwooly .
Arc S has low memory in both case internal storage & ram, so always clear cache for big apps like facebook.
and move all possible apps to SD card. So you can use your phone smooth and with out lag.
Davezy
I did use SUS but it says I have latest version and there is no button to install the current firmware.
I also flashed it and its the same thing ..
Any other solutions? I cant find any
shihstouch
Enthusiast
Even if you have latest go ahead with repair.
If problem persist contact Sony service centre...
try without the SIM and SD card
