xperia arc doesn´t vibrate ?!
i just got a sony xperia arc, but it doesn´t vibrate at all.
even though i have it on mode: vibration = all the time
in this case i miss all my calls when i have my mobile in silent mode at work
who can help?
7 REPLIES 7
Nabeel
Hey
Dial *#*#7378423#*#* in dialer  > service tests > vibrator > then press menu keys and voulme keys etc, to see if your mobile vibrates or not
Post the news here
where can i find the menu key? are the volume keys the keys on the right side?
Nabeel
Nopes, i have no idea about that,....
Try to change your mobile's language to english
settings > language and keyboard > language > english
and then do the same
i don't think its possible,,,, that menu should have been in english
Okh dial *#*#7378423#*#* in dialer
select 3rd option from above ( there must be 4 options ? right ? )
and then select the 10th option
see if you are able to reach it
i don´t get it 🙂
" select 3rd option from above ( there must be 4 options ? right ? )
and then select the 10th option"
after i dialed the number i select service tests  and  then there is a english menu with over 20 options starting with:  keyboard, touch screen, display etc.
so third option there is DISPLAY?
further down on the 9th is VIBRATION
i click on that and then it says: test vibrating alert pres MENU key or side keys
but i still dont understand where i can find the MENU key??
nothing happens when i click on the side keys on the right
Nabeel
Okh it means its a hardware defect....
Go back to the place from where you bought the phone
hmm but where can i find this menu key?
i acutally won this phone, could also a softwareupdate work?
when i look at this forum and on the net, there seem to be quite a few people where the vibrate modus doesnt work...
why doesnt sony read this forum and do something about it for example a software update etc.
Nabeel
This is not a software problem, but a hardware issue
Your mobile's vibration motor has stopped working .
Service center guys need to check and correct it Slightly_smiling_Face
