just wondering if any one has any ideas on how to fix my x10 phone ????????
last night half way though a txt message it turned it self off , restarted , and then restarted it self 6 or so times , now it wont
even turn on , when u take the battery out and then but it back in and turn the phone on all get is the phone giving a little vibrate ....
any ideas?
Hello, have you tried updating the software using Sony Ericsson Update Service? This should fix the phone.
can this be done with out the phone turning on ?
Yes, there are onscreen instructions which tell you what to do. The phone remains turned off while you insert the USB cable in to the phone holding the back button. Here is a link to the update service http://www.sonyericsson.com/cws/download/1/110/61/1294043165/Update_Service_Setup-2.11.1.9.exe.
The link is not available..
This link should work .... http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
My phone is ok now. Thanks you very much!!!!!! Wahhhhhhhhhhhhhh so happy!
Haha .... now you are 'spamming' other threads.
Continue to enjoy your X10.
gwhispererz, I noticed when i am using 3g internet, it always restarts /rebooting... Also when i am using my phone while charging... Any solution? thanks in advance.
My only suggestion is to run SE Update Service again (make sure you have your backup ready). It did revived your phone the other time, maybe this time is due to software glitch? If you are unable to resolve this issue with software repair, it could be a hardware problem.
Keep us updated ....
