x
1s
x
xperia M ,2 days back i bought new xperia m mobile,i found that mobile upper part temperature is high always(idle time-no heat).kindly do the needful
7 REPLIES 7
profile.country.RO.title
_alexdon_
There are the processor,GPU etc.So if you use the device intensely,there it will heat up first.
alexdon
1s
sir,this temperature is create any problem in the future?
ear piece side also heat is there.
how to check mobile inside temp?
kindly tell me premanent solution ,please?
_alexdon_
There are apps that will check the battery temperature,download from google play.If the temperature is too high,it is recommended to have your device examined at a sony service.
alexdon
1s
sir, i downloaded du battery saver application ,in that min temp is 32c and max temp is 40c is it norma l?
_alexdon_
For the battery or for the device? 40C is a high temperature but there might be cases when it will reach even more.
alexdon
1s
sorry how to check device temperature?
_alexdon_
I think there might be apps that will show you a relative temperature.Only for the battery there can be a known temperature through an app.
alexdon
