When input some text, for sms or contact entry, letters in the right hand side( P , L & cancel key) are not working. When I press these keys,keys prior to these ( O, K & M ) are coming in.
If I enter the same in Portrait mode, then there is no problem.
Pls help..
You can test the touch screen using Xperia diagnostics:
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
If the display works in the diagnostics test, try to repair the phone software using PC Companion:
If the screen doesn't work as it should in the diagnostics test I suggest that you have the phone examined by a service center. Please contact your local support for more information:
I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
