Wireless Headset Pro - Unable to set application settings
Googol1
Just got my Wireless Headset Pro. Paired it to my Xperia Arc S (running ICS, all bog standard, not rooted). Prompted to Install Smart Wireless Headset Pro plugin for LiveWare Manager, installed OK. Click on Smart Wireless Headset Pro from LiveWare Manage, click 'Applications and Settings', click 'Applications.' I then choose each application in turn and click to install - Calendar Remider, Messaging etc (go to Google Play Store and click the 'Install' button). All Applications installed correctly. Click again on any application (e.g. Messaging - Smart Extras) to change settings and get taken back to the Google Play Store to install the app again! The only option in the Google Play Store is the 'Uninstall' button.
Even through I've installed all the smart extra applications, they are not being recognised as installed by the LiveWare Manager plugin. The status of each Application in the Wireless Headset Pro LiveWare Manager says 'Download and Install'. They are showing as installed to the phone memory under the phone Settings>>Apps.
I have tried restarted the phone and the Wireless Headset Pro several times. Also tried resetting the WHP and re-pairing. No difference.
Anyone else found this?
2 REPLIES 2
Johan
You could try to clear data for the LiveWare app. If that doesn't help I think that you will to try to repair your phone software via PC Companion.
Let me know if this problem remains.
Googol1
Hi Johan and thanks for your throuhgts. I have just tried a 'clear data' for the LiveWare app but no improvement. Just had an email, (using the Gmail app and Gmail Smart App Plugin) but no notifiication on the WHP.
I really don't want to go down the 'restore' route at the moment as I've got the phone just how I like it and don't want to have set it u pagain. However once Android 4.0.4 is available I wil prbably do a completely clean install then and see if that makes a difference.
