Wireless connection between Z1 and PC
Cos_Marchy
I'm trying to connect my Z1 to the PC via wifi but I am having trouble with the last step.  After the two paired, I got a dialog saying I need to "...manually enable the "Wireless Portable Devices" firewall ecxeption..."
The trouble is where?  I use Kaspersky IS 2014 for my firewall, but I cannot find anything in there.  Is it in the Windows firewall (bit pointless if I use a third party firewall!!)?.
Once this problem is sorted, how do I access the Z1?  Does it appear as a drive in Computer or something?
Thanks
7 REPLIES 7
Thommo
Genius
If using Win7 then connect your device via USB then open Computer and right click your phone then select Network configuration accept on your phone to have settings pushed to it then once complete you should be able to connect without issue
Cos_Marchy
Hi Thommo,
I tried your suggestion however, I eended up with the same dialog box as before.
I even tried after disabling Kaspersky, still with the same dialog.
Thanks for the suggestion.
profile.country.US.title
Qatrium
I think it has something to do with your firewall's trust level. If you set your network properties to be public, a higher security level will be established preventing access from most sources. Try to figure out how to decrease security level of your firewall or add exceptions to it.
Cos_Marchy
Kaspersky is managing my firewall so I've disabled that to see whether it makes a difference.  The problem is, I don't know what I am looking for!!  Should the phone automatically appear somewhere on the PC, as a drive perhaps.  Or, do I need to do something on the phone to enable a connection????????
Once Kaspersky is diabled, I don't actually know what is supposed to happen, let alone what I should be expecting to happen Anguished_Face
Thommo
Genius
Once setup is complete then disconnect from your Pc then open settings then Xperia connectivity then USB connectivity and if all went well your Pc's name should be listed then tap on it and then tap on connect
Cos_Marchy
Ah,
Well this is particuarly odd.  Although I get this error, it will allows connection between the two devices.  Out of coincidence, I also tried my tablet and I get exactly the same issues with that also.
Oh well.  So long as it does what it says in the tin then all is well.  Probably on of those good ol' windows errors which means nothing????
Thanks for your help guys Slightly_smiling_Face
addry0
Oh dear. Mine had a failed attempt and now it says right at the end when pair button pushed "pc/phone already paired please unpair and try again" to my knowledge nothing is paired. I unpaired bluetooth??? Any help or ideas please?
