Will microSDHC memory card will work in Sony Ericsson Experia mini ST15i?
Malar
hi,
i am having Sony Ericsson Experia mini ST15i mobile.  2GB micro SD card came along with the product.
now i am planning to purchase 32GB or 16GB or 8GB memory card, depend upto the budget. but when search it is showing different options like 16GB micro SD, 16GB microSDHC and 16GB microSDHC class 10.
As my mobile supports upto 32GB,
1] does Sony Ericsson Experia mini ST15i supports microSDHC card? because in ST15i specification -->Expansion slot: microSD, up to 32GB
2] what are these class in micro SDHC card  define as? like class 10, 6, 4 etc.
3] which one will be better 16gb micro SDHC card class 10 or 32gb micro SDHC card class 10? will there will be any problem in device like slow reading/writing, phone process get slow?
3] which one is best - micro SD or microSDHC card?
4] which memory card brand is best? like trascend, kingston, strontium, scandisk, etc.
Please explain in detail if you can.
Message was edited by: Malar
2 REPLIES 2
Markus1
Leader
Xperia mini supports microSD up to 32GB. It also supports microSDHC.
If I'm not mistaken, all cards above 4GB are SDHC cards nowadays.
Class defines what speeds the card support for writing and reading data.
You don't need a class 10 card unless you will transfer a lot of files often and need to do it fast.
I'm using a class 4 card in my phone.
I'm using SanDisk and I've never had a problem with them. Have not used the other ones but I'm sure they work fine too.
Malar
1] will there will be any problem in device like slow reading/writing, phone process get slow once we insert 32Gb microSDHC card class 10?
2] which one is best - micro SD or microSDHC card? but in some website online store it says micro sd card 32gb class 10 cost 4xxxx and micro SDHC  32gb class 10 cost 6xxxx.
therefore is there any difference?
3] which memory card brand is best? like trascend, kingston, strontium, scandisk, etc.
