not being able to connect to the hotspot made by the laptop....... shows obtaining IP and does not procedde
Use connectify to make the hotspot on the laptop.
As above you will need to sue third party software to perform this function as when you use a laptop as a hot spot it creates an ADHOC connection point and the Android OS only supports Infrastructure type access points.
I am currently using mHotspot.......with JB 4.1 it was working properly. But after the update, it has stopped working. It dosen't even connect.
Forget the connection from your device and add it again.
already tried it.......still not working
Restart the hotspot and change the security protocol to WPA2.
