wifi unpair
memexz
wifi unpair
hi i have formated my phone and wanted to pair my phone with my computer so i cant find my computer and every time i try to pair it to send file over net it tell me the phone is paired so how can i unpair it
9 REPLIES 9
profile.country.RO.title
_alexdon_
Try to forget the connection from your device. Also,go to device manager and remove the device.
alexdon
memexz
removed the device from device and printer and cant find it on my phone still not working
Thommo
Genius
Connect your phone via USB then open Computer then right click your phone then open Network configuration and go through the process of setting up wifi transfer assuming your phone is connected to the same network via wifi then there shouldn't be an issue
memexz
@THOMMO still get the same error device already paired
Thommo
Genius
So have you gone to Settings then Xperia connectivity then USB connectivity and then check to see if your Pc is listed - If it is then tap it to connect or unpair from the options that appear
memexz
@THOMMO i have checked and no its not there
Thommo
Genius
Have you checked your Bluetooth paired devices?
memexz
yes
Thommo
Genius
If you have no devices listed as paired then I'm unsure what the issue is or why you have this
