i have a problem connecting my xperia S to wifi ... my laptop and other android mobiles are working fine !!
If you are running ICS as your operating system then welcome to the world of the bugs and the wi-fi problem which i'd say more than 2 thirds are having issues with
Check what kind of IP address you get from the router. You should receive an internal one.
Also check this thread for Wi-Fi tips.
Did not Work !!!!!
Message was edited by: 3amr
This is near to my problem, but mine is I can't find my network and my xperia s say it "not in range" how ever i stand beside the router and the other phones work 100%.
please help.
I Can t find a solution for this problem :S
hi , which country do live ?
i have this problem too that my Xperia SL say not in range ,
Egypt
first go to setting - about phone - status and say the IMEI of your phone .
if your problem is just that your phone say LIMITED CONECTIVITY you have to check the router setting or call to the operator ,
but if your problem is like : eshta_ya_7egazy : you have problem with operator of your country and andorid 4.0.4 .
it is not from the router because other devices like HTC (android) and my laptop are working fine ....It s an issue from the phone (doing same problem in other areas and routers :S:S:S)
