Hope you can help.
The phone doesn´t detect my home network. It detects all the other networks but my home network not.
Initially it detected the network and worked fine, I probably pressed the forget network and now thephone doesn´t recognise the network even searching networks it will recognise all networks arrround beside mine. All my other devices continue to work well just not the phone.
Again hope someone can help.
You put your SSID and passphrase in maually and it will work providing your router is set to channels 1 to 11, if you are using 12, 13 or 14 you will need to use 1 to 11 to get it to connect then once it has connected you can set the channel back to 12, 13 or 14.
