WIFI problem in NEO V after ics update.
I am facing some problem in wifi...After connected i am able to browse for some tym then it gets stuck n again after few secs it works... i don't knw what the problem but the connection isn't consistant....
122 REPLIES 122
Neo V ICS > wifi connection to WPA2 problem. Please fix this bug...
Johan
Try the tips suggested in this thread.
http://talk.sonymobile.com/message/154244#154244
Let me know if none of them helps.
MSC3
NEO V ICS - Poland.
None of them works.
WPA2
Network mode/ speed: mixed b/g
SSID and password: none of  special or extended characters.
DHCP: turned on.
Mac-Filter: turned off,
Channel:Channel 9
Johan
Try repairing the software using PC Companion.
Let me know if problem remains after software repair.
The same problem, repairing didn't help
reinstalling does not help
MSC3
Everything was ok before upgrading to ICS.
I have tested on 3 routers - on 2 doesn't work, on 1 work perfect.
The same type of security on all - WPA2
Johan
But if you change security from WPA2 to something else will it work?
If yes, please post the router models that you've tested and which of them that did work.
MSC3
Without encryption works fine. With WPA2/MIXED or WPA2/AES not.
Tested Router:
AirLive WL-5470POE
On my TP-LINK Wr-540G WPA2/AES phone works.
