Wifi not getting connected
ivanreny12
Hi Guys.. whenever I connect to a wireless network, it shows "scanning, connecting, disconnecting". and this process goes on without connecting to the network. what should I do?
my build number is 6.0.B.3.184
3 REPLIES 3
Raja22223
ICS is Available now, Connect the Mobile to PCC and update.... Slightly_smiling_Face
ivanreny12
Today i updated to ICS... coollll.... but yet to check wifi issues.....
ngtvk
Hi there.
I am experiencing the same problems. I sent it to the service center, repaired the phone using both SUS and PCC but no luck. OS is still GB (6.0.B.3.184) btw, ICS is yet to come to my region. Could you let me know if the problem still persists after the update?
I have problems connecting to my router at home, tried changing the channel but nothing changes. Other devices connect just fine. It might be because the wave strength is weak in my room but the previous phone I had connected just fine from the same room. I'm guessing it's just compatibility issues with my router as it can connect to other routers with absolute stability.
I didn't have this issue in 6.0.B.1.564 so I think it is a software problem that can be solved with a patch.
