Wifi lagging problem
Aravind07
I buy sony xperia x before 2 week. I am facing too much problem in wifi connection. Taking much time to load images and the lagging problem. This problem occurs even when I am using in 2.5&5ghz.
Pls help me to resolve this
5 REPLIES 5
@Aravind07
Could you test it in >>> safe mode ? does it happen with other routers?
edmonddantes182
Hey Aravind07, I know this is going to be a simple answer but have you tried resetting the router?
YoGem
Leader
So for lag you mean low speed? Can you try to download the Ookla speedtest from play store and trying first WiFi and then with mobile data? If you say that your phone is connected to a dual band router, can you try to enable only 2.4ghz, try the speedtest, then enable only 5ghz and trying again speedtest?
Does this happen when Bluetooth is on?
stewy85
My wifi is definitely a bit buggy/laggy since moving from Z3 to X Performance, I have to turn wifi off and use 4g for faster speeds. I have Bluetooth on always and I have seen this may be causing problems?
profile.country.PL.title
madbrow21
New
I have the same problem since moving from z2 to x performance.
