I have used the phone for 2 days, but I found a problem on the wifi connection - the mobile phone fails to respond on the wifi signal. I have been using the same wifi signal for other devices without any problem.
The first time I saw this problem is that: in the setting -> wifi button, I cannot turn off or on the wifi at all. It's status is on but it does not respond at all. But I cannot use the wifi connection at all. So, what I need to do is to turn off the mobile, and turn it on again to get back to normal.
The second time, the wifi button is responding and it is on. But it does not connect to the wifi connection automatically. And I tried to choose the wifi connection myself, it still does not do anything. I need to turn off the wifi module of the mobile, and then turn it on again to get connected.
Could you advise if this is bug of the firmware? or I should send it back to Sony for repiar/replacement?
Thanks ~
Regards,
busybees
I have the same problem. Solved by off/on the function "location-based Wi-Fi".
Which software version/ build number are you running on?
Settings > About phone > Version/ Build number
Hi I have the same problem with wifi.
And sometimes my phone get warm and the battery runs out of charge in short time.
4.0.4 / 9.0.D.0.484 (RU)
P.S.: Also, sometimes it is impossible to make a call.... no dialing tones. Helps only restart the phone.
same story here. using it for about a week and it loosing wifi/location based wifi even when I'm here almost 24/7.
please tell me that its easy to fix bug
