I have a sony ericcson xperia arc i am unable to connect to WIFI router with wpa2-psk .I am unable to browse the internet can you help me out Currently i am in USA,
I have got a few questions and actions to try
1) Do you have administration access to the WiFi router and are able to make changes if necessary.
2) Does the WiFi router use MAC address filtering.? If it does, you will need to add the MAC address of the phone as allowed.
3) Can you please double check to see if you have entered the correct details for your WiFi network in your phone settings. Quite ieasy sometimes to accidentally have a typographical error.
4) I assume your WiFi router has access to the internet and there are no firewalls preventing your phone from accessing the internet.
5) Not sure if you have tried to reboot the WiFi router
6) Can you also try to perform a settings reset on the phone to see if it helps.
Go to the settings menu ---> Privacy ---> Settings reset
Please back up the phone settings before proceeding.
7) If that did not work, can you try factory reset on your phone.
Go to the settings menu ---> Privacy ---> Factory reset
If all the above actions did not work, can you try to perform a software/firmwware repair using PC Companion to see if it helps.
Connect your phone to the PC via the USB cable
The repair option on PC Companion (Support Zone --> Update --> Repair).
Please backup your phone data and settings before proceeding.
If that did not work, can you try the SE Update service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
Download, install and launch the update service on the PC. Follow the onscreen prompts.
