Hello There! I have a wifi issue and wonder if anyone ever had this problem.
I have Wifi turned on and connected to a wifi at home and also at work. but for some reason , sometimes I check my phone and i see the H+ logo meaning that its on the 3G and not in the wifi. I check and the wifi is still turned on.
I can manually fix this , by turning wifi off and turning it back on and it will automaticly connect to my wifi.
But this happen way too often...
Help please!
Thanks
Sometimes the phone disconnect from WIFI and then 3G takes over. Check how strong is yor WIFI signal, also the latest sw increased the WIFI strenght, at least for me.
well my signal is always strong , at home I got a powerfull routeur and at work the router is in the same room
Before we look at some other options, please ensure you have worked through the various steps outlined here: http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104#U348104
Ive checked everything and this is correct..
I thought others ppl had same problem.. it does it all the times..
instead of being connected to wifi , it always switch to 3g.
All others have an Iphone 5 and does not have this issue..
I had my Xperia Z1 replaced 2 month ago for another issue , but I had this wifi issue with my other z1 too
Open the Wi-Fi settings >Menu Button > Make sure that "Keep Wi-Fi on during sleep" is set to "Always and that "Avoid Poor Connections" is unticked.
The main reason why I bought the Xperia Z1 was for the Camera. I mean , having 20.7MP with supposed great low light picture (like in the commercial)
I noticed many ppl have this problem.
This smartphone takes Amazing photo.. but in Day light only.. As soon as the light is a bit low.. the photos are REALLY ugly.. many noise , nothing sharp .. really ugly..
For example I went to a restaurant last week , someone took a picture of my family He took 3 just to be sure.. none of these was even acceptable..
If its supposed to take GREAT low light photo like they advertised.. They should fix it.. I dont know if its hardware or software problem.. By I am so disapointed..
I usually change photo every 8-9 months for the new one.. But I am not even going to buy the Z2 because of this..
Other things.. Bluetooth and Wifi **bleep** **bleep**.. Each time I am on my wifi on youtube.. well every time I play another video , its saying Connection Problem, then I press 3-4times to Try Again and it finally work..
I hope they will fix it.. we paid 700 for that phone.. we need support..
Sorry for my english.
