WIFI having problem.
aj_kr_choudhary
Hi Friends,
I had update my phone to ICS. But since few days I am having problem with the USB and WIFI hotspot.
USB hotspot doesnot work at all, and WIFI hotspot works but when ever incoming or out going call is made, WIFI hotspot stops working.
And if tried to restart the WIFI hotspot hangs out. Finally need to restart phone to get it working again. And the same story keep repeating.
Kindly help me out for the resolution.
Johan
What OS are you running on your computer? (In regards of the USB tethering not working)
It sounds like there could be some network limitations or that you only have one network available therefore the Internet connection stops when a call is being made. However the Internet connection should be resumed after the call. I suggest that you try to repair the phone software using PC Companion to check if it's a glitch in the software somehow. But you should also contact your network operator just to be sure.
