MY xperia s have a bad wifi error..when i turn wifi button..its alway show turning on but no working,phone can't connect wifi AP then i can't driver my wifi button..Can support team help me?i tried hard by repair over SUS,PC companion but nothing happened..now i can't use wifi on my xperia smart phone.
I see you are using the JB leak. Just reflash the ROM after going back to .55 firmware (use another kernel) follow the steps given by DooMLord.
Help me,
I repaired to stock ICS .55 by SUS and PC Companion but wifi still not working.
Anyone help me! My xperia have a bad error.
I see the same problem here http://talk.sonymobile.com/message/456406#456406
Sony support can see that and help many customers having bad wifi.
I would recommend that you send in this phone to a service center for repair, as it doesn't seem to be software related. Contact your local Xperia Support for more information:
Sending to a service center didn't help me at all......
I to am having this problem on an Xperia S (LT26i). I have read many, and I mean MANY posts to this forum and others of this being a VERY common problem and still there is no fix. I did take the advice and my phone went to a repair centre and it came back and I was told that it was irrepairable and would cost more than the phone!! I had only had it for 7 months!! Tied to a contract and had an expensive brick!!
So I have SUS'd it, downgraded it and got the wireless to work only to start using the phone again and it stop working again.
I have got to say that I moved from an iPhone 3GS to what I thought was a decent phone (Sony) and a tried and tested OS. I actually wish that I had never wasted my money and stayed with IOS and Apple. I didn't have a single issue in the 3 years with that phone.
I have subsequently upgraded to the newest Jelly Bean after several other software and OS changes. I got the phone WIFI working again (no hardware replacing, no costly repair)!!!! However again after several days the WIFI will not connect to any 'known' SSID's which is complete crap.
Also WIFI will not turn on unless I do a hard reset (hold power and up volume key and wait for the 3 vibrates). Turn it back on, take out the SIM (the Xperia reboots), then put the SIM back in (the Xperia reboots again) and then WIFI turns on and operates for a day. Then STOPS.....
Just to add I do not have any AV or app running my wireless connections. I have SUS'd, upgraded, downgraded, flashed, factory reset the device so many times that it is pretty much first time boot other than turning off touch tones.
This has to be a software, driver or other issue rather than hardware!!!! If it was hardware it would just NOT WORK. There are also SO many owners of Xperia S devices having this exact same problem/issue that I cannot believe that Sony has an inherent hardware component issue in all the phones.
Has anyone found a way to reslove these issues or is Sony actually listening and trying to resolve them themselves????
