Once connected to wifi, whenever the phone is on standby for a few minutes, the connection is lost -- as if it deactivates wifi.
Once I start it back up and enter my password, it will automatically connect again. But this means I can't receive skype calls and never get any email notifications.
Any advice?
Which build number are you running on? Have you tried any software reinstall via SUS lately?
Hi Johan,
Android-2.3.4
I have configured "Settings" - "Wifi network setting" - "Inactivity" - "Never"
Accessing "Sony PC Companion" it suggests upgrading to Android-4.0, but I don't want to upgrade to verson 4.
Strange. If possible check if the same problem can be replicated on other routers as well. IF you wish to remain on GB I suggest that you contact your local support team for help doing a SW repair staying on GB.
Hi Johan,
Thank you for your answer.
It happens in any wifi network.
I have seem the same problem on other users, here, without solution:
http://talk.sonymobile.com/message/158934#158934
Note that I just CTRL-C/CTRL-V his problem description
In that case I think that this problem needs to be examined at an repair center to find a fix for it. Contact your local support team for more info.
