I have Xperia ray which has android 4.0.2. Problem is that, I see reconnects to WIFI every 5 minutes. In another word, while I am working with internet, I see that the WIFI icon (near the clock and battery indicator) disappears and when I go to settings->Wifi, it says that obtaining IP address and then the connection is established.
You may say that there is a problem with the access point (sort of ip conflict...) but my laptop which (windows) has no problem with the access point. Also IP conflict isn't possible, because the access point is a home staff and I test it while the laptop is turned off.
How can I debug more about that?
Just to narrow down the cause of the problem, do you have the same issue with other access points?
Yes. If I were in linux, there are multiple tools for diagnose. tcpdump and so on
