wifi direct
hari012
wifi direct
is wifi direct is not available on xpweria m???
There you go
http://userguide.sonymobile.com/referrer.php?region=gb&product=xperia-m#Connecting-to-wireless-netwo...
Wi-Fi Direct™
Use Wi-Fi Direct™ to connect to other devices directly, without joining a traditional home, office or hotspot network. For example, you can enable your device to be connected directly to a computer so that you can access content from your device on the computer. The devices that you share content with must have Wi-Fi Direct™ certification.
To turn on Wi-Fi Direct™
  1. Make sure your device has the Wi-Fi® function turned on.
  2. From your Home screen, tap Application screen icon in Sony Smartphones.
  3. Find and tap Settings > Wi-Fi.
  4. Tap Menu icon in Sony Smartphones > Wi-Fi Direct.
Don't forget to give Kudos
