WiFi direct not working in ICS
Parminder
I updated my Xperia U with ICS 4.0.4 & faced the problems like
1     WiFi direct not workin
2     Backup & restore not working &
3     Some performance issues
then again I repaired the software & rest of all issues resolved except wifi direct.
then i reupdate the software from sony service centre but the problem still persist.
kindly help me out.
thax
4 REPLIES 4
Johan
Can you please describe the problem you're having in more detail?
rcanzia
Hello, I have the same problem on my Xperia U ICS 4.0.4: when I activate the wi-fi direct under wifi settings, it turns on and there is the icon in the status bar, but when the screen goes into lock and then I unlock it, the wifi direct turns off switching to normal wifi mode, even if it was not activate before; I tried anyway to transfer some files with wifidirect on, pairing with a LG L9 without letting the screen lock, using WiFi Shoot or other apps: sometimes the connection succeeds between them, but no way to transfer files, and anyway even if the phones are connected if the screen locks after unlocking it always switch to normal wifi mode and connects to my wireless network.
Am I doing something wrong or is a known issue in U?
Thanks
Parminder
Hi johan.
The problem is exactly same as described by "rcanzia".
Parminder
Hello, when I activate the wi-fi direct under wifi settings, it turns on and there is the icon in the status bar, but when the screen goes into lock and then I unlock it, the wifi direct turns off ; I tried anyway to transfer some files with wifidirect on, but there is not any option to scan or select the device.
Thank
