Wifi DIRECT issues
sacredbloom
Wifi DIRECT issues
Dear all,
i m using Xperia Z. unable to send and recieve files over wifi DIRECT.tried out all possible options available in online forums, went to local sony service centre but issue not yet resolved. Can anyone help please?has anyone faced a.similar issue?checked many other handsets,"the wifi DIRECT feature seems to work well in Samsung phones.
Regards,,
scrdblm
6 REPLIES 6
GeoffH
Enthusiast
My EZ is permanently connected to my laptop over wifi, only requirement is that you need to be on the same network/router
I did this by using PCC and the "how to connect" function on the top left hand corner of the app window
unfortunately when 2x platforms try to come together it's not always easy until a standard is formed
http://forum.xda-developers.com/showthread.php?t=2055413&page=2
sacredbloom
Did you try sending or receiving a file from another XZ or Smsung Galaxy??i think it wont work!!Sony technical support any help please?? Or would this require a handset replacement! On pairing the wifi devices it shows both devices as connected but the connection fails when a file transfer is initiated.Is it a device / brand compatibility issue irrespective of the fact both have same latest android running?
hector121
Same issue here
GeoffH
Enthusiast
okI have this working on my device between my EZ and Lappy using the the lappy as a hotspot
First I recomment you go through the pairing proceedure first that I mentioned above using PCC
During this process you have to connect the phone via usb, it is a type of security to give permissions to the pc to access the phones file system - pair the devices
once you have done that then do the following (this depends if your lappy has a compatable networks card or not - mine does)
using one of the wifi mini ports  (I disabled the other)
open intel proset wireless and set up the wifi connection - ssid password etc
open your main wifi connection and enable internet sharing  - adapter setting - sharing ICS tick the box
once you complete the above go into wifi and connect to the ssid you created above (miniport proset)  you should be able to connect as with any wifi connection
next go into the phone and setting - experia - usb - and click on the previous connection you had during the pairing process above and disconnect then reconnect
you should now have full access to the phone through your pc and be able to transfer files etc
PS I also have my TV connected to my main wifi connection through the TV lan port to computer lan port by bridging the lan and wifi - on the computer select the two connections holding the control key right click and bridge
don't know about connecting two phones together but this works on my laptop and phone
sacredbloom
Many thanks Geoff for your responses but  the forum  link you provided concludes with the same statement that Wifi DIRECT works well only for Samsung. Phones.the process u explained is useful but doesn't help resolve the issue of not able to connect Xz to another Jelly bean phone using WiFi DIRECT.seems i have no option but to change my cell. Slightly_frowning_Face
i shud have waited for S4.
GeoffH
Enthusiast
not a problem and sorry I couldn't offer more help, I don't have another device to try
One thing that has raised it's head with this full on wifi connection to my lappy is the constant disconnect connect and that is with a very strong signal, I had to turn off the notification sound as it was going off every few mins
