WIFI connection stability
Yaroslav
My C6833 14.1.B.1.532  keeps losing wifi connection. After short time the data stops transferring but phone still is connected to network. Sometimes it works after hitting "reload page" but often I have to turn off wifi on my xperia and than turn it on and connect to network again. And than it loses again and again. This is not a router/network failure because I tested this on several networks (home, work, publc) plus and at the sam time my C1905 works perfectly on the same network downloading same content (webpages, apps etc).
 P.S. When I turn off wifi it turns off quite a long time, longer than when I turn it off when it's working fine, hope it might help
3 REPLIES 3
Raffy
The warranty card is always present if the phone is brand new. So I suggest you go to the nearest Sony shop, bring your warranty card and ask them to help you personally.
Yaroslav
what shop people can do? nothing. It seems to be software bug
I used PC companion to reinstall OS, but wifi problem is still on plus I got SOD
zxcvbad
Wifi stability is a software bug in current firmware. We'll see if it'll be resolved in upcoming updates
