after upadating of 4.3 i have lost my wifi connection even it cannot be on the feature. but i found when bluetooth is on i can swith on wifi but suddenly it closed what should i do now. do i want to downgrade plz tell me
Do you experience the same behaviour if you boot your phone into safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
If yes, I suggest that you perform a software repair on your phone via PC Companion:
http://www.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
i accesed to safe mode but it didn't work. if i repair will it be worked??
If the problem is related to a software issue, then a software repair will help. But if the issue remain after performing a software repair, I suggest that you visit nearest service center to have your phone examined by a technician. You can contact your local support team for further information about nearest service center and/or how to proceed with this in the best possible way:
