hi, i am using sony xperia miro phone, there are some issues related to its wifi use. first is that i am not able to connect to my home wifi network, ie my home wifi network is showing as "out of range" while other wifi networks are working fine (when i am well within the range of my home wifi network). it is showing my home wifi network and i am bale to connect to my home network only after restarting my phone 2-3 times. plz help me regarding the problem
regards
ravi
Forget the home wifi network you have already added in the phone and manually add it again.
thanx for the reply sir.......... but i have tried everything......firstly i removed my home network by the option forget network.....then i added my network manually .........but again......it showed that the network is not in range........
I have same problem
i also having the same prob, but
b4 this i restart all setting and it work fine but after that it won't work anymore even i reset all seting and delete some data.
can anyone help me!..
