Good Night:
Today I update my Sony Xperia T to Google Android 4.1 (Jelly Bean) Version: 9.1.A.1.141. Since I made this, the WIFI is connecting/disconnecting with out reason, I'm on the same distance than I didn't have problems before with the old version, so I want to know if somebody had the same problem or have any solution about this problem.
Hoy actualize mi Sony Xperia T a Google Android 4.1 (Jelly Bean) Version: 9.1.A.1.141. Desde que hice esta actualización el WIFI se conecta/desconecta sin razon, estoy a la misma distancia de la cual no tenia problemas con la version anterior, quisiera saber si alguien tiene el mismo problema o si alguien sabe de alguna solución para este problema.
I wish you can help me.
Espero obtener su ayuda.
Repair / Update Service
Update your phone for optimum performance and get the latest enhancements. Regardless of whether you have the latest software, it’s a good routine to run the Update Service to improve software stability. Also, if you experience problems with your phone this may be solved by a software update.
I made the reinstall and repair for the update, but still have the same problem with the WIFI, other funtions works fine, i just the Wifi, than give me problem. There is a way to get the old version of Android on my phone, because in that i didn't have this trouble. Thank you.
You can take to a Service centre, they can downgrade your OS...
Or
Flash your device, so u can install custom roms...
Before you look at other options, do you have this problem with just one connection or multiple?
