Widgets are shrinking!
zoli0726
Hi, im facing with some problems on my Xperia Mini, both on ics, or on gingerbread, the digital clock widget and the switch widgets are shrinking sometimes and i always have to close them to fix the problem. I tried to repair both firmwares, and formatted my sd card, but its just happening anyway, and quite often. Did anybody else experienced this problem? its happening to me on both firmwares.
2 REPLIES 2
Johan
I have encountered this sometime before but I'm not sure what causes the problem. I suggest that you check what other app's you have installed if one or some of them could be related to the problem.
Do you have many widgets on your home screen? Have you tried using other home screen app's as well?
zoli0726
its not an app related issue because its happening too on both firmwares without installing anything(or just the updates). Ive tried that.The simplest way to cause the problem is browsing to me, i open some pages, and when i quit to the main screen, the digi clock widget is shrinked(not every time, but often). I useing only about 4 widgets, a digiclock on the main screen, a weather widget and a wifi switch on the left screen from the main, and a music player on the right screen from the main.
On gb its not that bad,its just happening rarely, but on ics quite often, i wanted to use ics, but its irritating me, and if i change the laucher the weather and the music player widgets are missing.
