Hi all
I have an xperia arc recently updated to ICS.
My son has, by accident, erased the 'Multimedia' widget. See image below.
I tried to re-install it, but I have a problem.
The phone says that the widget can not fit on the screen. On the same screen it was erased from!
I have tried to install it on another screen and the "shadow" of the widget is actually a lot bigger than the widget. So this is the problem, I think.
I have tried other widgets and the photos widget (the one above the multimedia widget) has the same problem.
All other widgets are OK, they occupy the same screen area as the widget size itself.
Can anyone help?
Thank you!
You're likely going to have to reset the phone. Either in the menu or via PC Companion. Its sounds like a strange software glitch.
