hi .
i bought a x5 . 5 days age , and the day i bought it , i updated it to android 5.1
it's about 3 days that i have this problem with my phone's wifi :
it connects to my modem .and i have internet access . but internet disconnects and reconnects randomly . it takes about 5 minutes over 3 hours to get connecting to the net . but i have my wi-fi icon connected to the modem all the time . ( phone connected to the modem but no internet access randomly) . i tried all solutions ( restarting the phone & modem ) ( setting ip ) and .... but no solution yet , and i have another phones and laptop connected to same modem but there is no problem on them .
please help ...
Have you seen this FAQ WiFi guide?
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104#U348104
thanks for your help ,
yes i tried them all but nothing
Hi mmoni,
Welcome to the community,
Have you tried connecting to another Wifi connection, one that is not your own and if so what is the result?
@mmoni wrote:hi .
please help ...
This sounds really like congestion problem. If you are seeing like 10+ access points from your phone, when you connect, then it is very likely that this is a congestion problem. Basically there are too many access points and devices, that some devices will not be able to transfer data properly, even when the wifi is connected.
The first way to try to get around this problem, is to change the channel on your router, you can read more about how to in pages like these:
Secondly, you can try out a dual band router which can also serve at 5Ghz, M5 supports the 5Ghz band, and most laptops also do. So you should see a lot better connection. I just switched to a dual band wifi router 2 months ago.
because CPU MTK Helio X10(MT6795)have problem ,many smarphone have this problem.
