Wi-Fi problems X10 mini pro
hello again. can somebody tell me why can't I connect to my home network? the Wi-Fi is enabled, I found my home network, entered the password, pressed connect and nothing. can somebody please tell me why. Thanks
5 REPLIES 5
I made my home network opened and still nothing. I disabled the security and nothing. I changed the wireless mode from mix B/G signal to 802.11g and still nothing. I think the problem is with my phone. can somebody help me please.
Please guys tell me if u think it's the phone. I don't wanna send it back if it's not the phone, I will b charged for the phone inspection and I don't want that. Thanks.
have you tried connecting to someone elses wifi, ie mcdonalds or somewhere?  at least you should know if its your home setup then as the free ones out and about tend to be easy to connect to.
the problem was my home setup indeed. I replaced the router that I had with an older 1 and it works perfectly.
I had the same issue but noticed that I could connect to some public wifi like Starbucks.
I updated the firmware on my Lynksys router which fixed the issue at home.  It's not universal unfortunately as some routers are still an issue.
