Wi-Fi dropping out
AndyT
Wi-Fi dropping out
Does anyone else gave issues with wifi on their z1c?
For me, trying to browse the net is painful and tedious, yet three computers in the house, my Samsung note 10.1 and my girlfriends phone are all fine.
I've done all of the pointless restarting. More usefully, I've downloaded and apparently that tells me which h wifis are available near to me, and which channel they are on, and changed my channel to one that is not in use.
Yet I'm finding I'm having to tap links a few times to get them to load, and even then it takes ages.
Next to the router, or a little distance away, it plays up regardless.
Tags (3)
2 REPLIES 2
manjuboyz
Hi AndyT
>you can try removing all wifi networks on your phone, restart it
>then start connecting it , with your network and see whether it works or not
>if possible try connecting to different wifi network if available and see it connect to that network too, if it is not connecting then there might be problem with the phone software
let us know
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
huesos1
Still doubt,  the wifi disconnects?
Or goes connected but not browse the internet either?
Try this, turn off and turn on the router, to synchronize again.
After the router has synchronized (usually a few minutes)  try again to see if the wifi so well connected and well let you use internet.
A greeting.
