who has these kind of problems of xperia Z2?
LiberOz
hi all
there are some problems in my phone
There have been 5 batches of Sony Xperia Z2s from the original release until now. Some of these batches have different problems and issues. Follow the guide below to find out what batch your Xperia Z2 is and whether it has any problems.
To find the batch number, remove the SIM card slot. In the slot is written various information about the device like the IMEI number, serial codes and the manufacturing date. You need to see the manufacturing date. The present batches are 14w15, 14w16, 14w17, 14w18 and 14w19.
he first one, 14w15 has a small gap on the top (the part where the screen and bezels meet), dead pixel and also the camera lens is off centered.
The second one, 14w16, has a problem with the double tap to wake feature, overheating issues when using the camera, gaps on the top and off centered camera lens.
The third one, 14w17 suffers from overheating when using the camera, 1 mm gaps on the top and the bottom, off centered front facing and rear camera.
The fourth one, 14w18, has a big gap on the bottom, dust under the screen and camera lens, dead pixels, overheating issues when using applications and the charging port doesn’t close properly.
The fifth one, 14w19 is the batch with less problems. It has a tiny gap on the bottom and again, the camera is off centered.
What batch do you Xperia Z2 owners have? Do you have any other problems that haven’t been mentioned above?
mine is 14w18
what is Sony gonna do for this problems?
9 REPLIES 9
blackmagic
These generally are not a problem. If you have such a problem you met with company officials report the case.
Gooders2
I have no issues with my z2 apart from software related but physically it's gorgeous
mpeel007
I had so much problems with my z2!!!
It's overheating by taking normal Fotos oder playing games!!!
To much space between frame and glass and a camera that is not in center.
Myne is 14w16
D6503
Ahmad007
Well I close the microSD lid on my Z2, it goes little bit deeper in the frame of the phone than it should be, I don't know if it's normal or if it's an assembly issue, other than that, I don't have any problem.
kayman
Mine is 14w15.
My Z2 got a gap on top right and big gap on the bottom left(1mm) which allows some dust to get in there.
Futhermore my camera protecting class (rear) seems to be odd since i've got already 1 big and another minor scratch on it though im always carrying my Z2 in a bag. No Idea where this came from... So frustrating.
It's my first xperia smartphone and unfortunately i'm already really disappointed after one month of usage...
biistu
My MicroSD lid also goes a bit deeper than the frame and it's a bit annoying. Nothing fatal though I think
dm841
well 14w17 have no issues what so ever wth my z2 physically everything works even better since to last firmware update i did if your handset is faulty, take it back to where you bought it from and get a new one . not that difficult
bb21
my batch is not listed... mine is 14w13
it has a gap on the screen
355609069658010
Mine phone' batch number is not listed here.It is 15W 12.What is about it?It has tiny gap on top and bottom and got overheat eaisly.
