Hi guys, as the title says, ive a problem with my phone screen, its completely white, altho if i tilt it i can just make out the normal and flight mode start up options
Ive had the phone for 2 years now, and havnt used it in nearly a full year because of a faulty screen which would only show a black/blank screen, after a quick search of the web i found i could fix the phone myself with new parts, which i made sure were either genuine or had a good review, i replaced the LCD screen thinking it was the problem but also replaced the upper and lower keypad membranes, battery, the flex ribbon that connects the screen to the motherboard and the speaker flex ribbon, ive made sure the ribbons and membranes are properly connected and in the right places and there are no problems.
Im now stuck and dont know what else to do, i fear that it may be a motherboard problem and have wasted 50 quid trying to fix something thats not fixable, if you guys have any other suggestions or ideas i would be very greatful to hear them
Many thanks in advance
Srimera
http://www.sonyericsson.com/cws/support/mobilephones/downloads/w595?cc=gb&lc=en I suggest you try running the SE update service and/or a phone repair with PC Companion.If this fails to fix it, then take it to a service centre.
I suggest that you follow Dr_Chris advice.
Let us know how it goes.
