where internal memory of my xperia arc is using when i m using less then 10 MB and still get notification of low memory
the problem i m facing is that my whenever i tried to install any app on my xperia arc...there was a notification of low memory...when i check internal memory of my device i found that 323 mb used and 57 mb free...when i check my internal memory apps i found that there are only 3 or 4 apps on internal memory of my arc rest are on SD card...and these apps are using maximum 10 mb of internal memory...i want to know that where is the rest of memory using when these 4 apps are using less then 10 MB of memory?
kindly help....
when i got my arc i installed too many apps and there are atleast 13 slides on my device full of apps but now i m now 5 slide n it says low memory when i tried to install any other app...can any one tell me where my fone's internal memory is being used?
9 REPLIES 9
Nabeel
Go to settings > apps > on SD card
TAKE several screenshot and ost it here
make sure every app is covered in the screenshot
that's normal, you need about 30MB or so of free internal memory not to get this messages
you can partition your SD card to use it as internal storage
http://talk.sonymobile.com/message/142152#142152
i have taken screen shots of apps...
http://www.ziddu.com/download/19751787/screenshots.rar.html
all of them are inside this folder
i tried this before posting here but it did not worked...my fone was not rooted
how come it didn't worked? it does work
The problem is that my frnd..first I have to roor my device according to that procedure...but when I followed that procedure for rooting ...too many errors were appeared on screen...tomorrow I will take screenshot of that cmd window
May b after that u can understand it more clearly...
Thowe errors occurred in the end of rooting process...
btw do you have ICS or GB?/
Nabeel
Oops, buddy i said you to send the apps on SD card
