whatsapp issue
shalika
whatsapp issue
whatsapp is asking me to adjust my clock but my date and time is correct. what do i do ?
6 REPLIES 6
yogesh_marwaha
Restarting the phone should fix that (this should only happen if you had removed the battery)... The problem is just that the time was not set when whatsapp started... you may also stop whatsapp (running as well as cached processes) and run again.
sildebangsu_gma
Same is the problem with my phone. I tried restarting but it dosent seem to work.....
DeepanshKhurana
Hello
I used to have this issue on my Live with Walkman (WT19i) too. Take your sim out, place it again, then start the phone. Go to time and date and set Use Network for Tine and Date settings.
Whatsapp will work.
Deepansh
Rahul_Agnihotri
I just bought phone yesterday and had same issue.
Tried clearing cache, force stop,restart, phone restart... but none worked.
Then updated whatsapp version to latest version and bingo! So would suggest following steps:
1) Setup the date time to auto update
2) Check if Whats app latest version is available.
3) Update if availble and recheck.
4) If this doesnt work then try restarting phone etc.
Dip_xperia
just update the app from market or uninstall and install from market. Will be solved.
ashwin21
had the same problem..just uninstall the app. from settings & download & re-install it from play store..IT will work. Slightly_smiling_Face
