hi guys when I look at my apps in th setting menu I see it like this:\
Total:xxxx MB
App:xxxxMB
USB storage app: xxxxMB
my question is what is the difference between App and USB storge app? and why does the app uses space on both SD card and Internal memory? and can If the app is on sd card can I det the app files on Internal memory?
I'm a bit confused here. Apps can use space on both internal memory and SD card, depending on how they are programmed. Where do you find USB storage app? Do you have a Xperia Ray or did you post in the wrong section?
yea I have ray
Good, then can you please answer my other question?
I find it when I go to settings then apps then click on any app
