What is normal temperature range for Z2 ?
Neoshogun1
my phone while normal usage gets easly hot na battery temperature variates between 38 C and 43 C.
What is normal temperature range for Z2 to work in before it gets damaged ?
22 REPLIES 22
Hampus
It's actually hard to say what the average temperature is since it can depend on the usage/environment etc. If the phone gets to hot, you will receive a message which says so and thereby, the phone will automatically power off to prevent overheating and damages to the device.
Neoshogun1
Too hot has to have a number. If phone turns off when it is too hot it means that there is a safe threshold. I want to know how much in C is too hot threshold.
Hampus
It can vary between the different components in the phone and unfortunately I don't have any specification for this.
profile.country.RO.title
_alexdon_
I cannot tell you about Z2 exactly,but on many devices the temperature at which the battery works at its best is about 30 C.If you reach somewhere around 50,it will be a little problem.
alexdon
Chrizz
if i Play a Racing game on the Z2
the app "A1 CPU Tool" show my Cpur Temp is 63°  after i close the game and go to app and Look temp.
So   im sure while Playing the Cpu 65°and higher.  is this ok?
on my PC my 4,5GHZ i7   isnt going so hot Grinning_Face
_alexdon_
You should also check antutu or hardware info,if they tell you the same,the phone does heat to 63 and it is pretty intense.
alexdon
Chrizz
they telling me nearly the same   1-2° only diffrence
so my phone Cpu getting 63° or more and im using it while i have a room Temp of arround 20°  cant imagine how hot the phone is getting when i use it outside in summer at 35-40° Temps
:O:smileyshocked:
_alexdon_
It can get hot,the heat is produced by the CPU and GPU running at full capacity while playing high demanding games.
alexdon
Chrizz
okay, but i think its also getting too warm just surfing on google search site.  Slightly_frowning_Face
with Wlan and using Chrome, (all other apps closed not minimized) its arround 40-45 °   thats ok?
