whenever i connect my headphone to the phone google now opens up. its mic and play/pause button not working but the mic and play/pause button working fine on other phone.
the weather widget frequently shows wrong animations. in the night its showing its still sunny, when i tap it to refresh then again sunny weather when its dark outside and also shows cloudy sky or raining even when it is a clear sky.
And lastly the very annoying mobile data connection dropout. it happens 3-4 times in a day. on the status bar it shows the outgoing data sign but the incoming data signs constantly blinks. at this time mobile data is not working and after constant blinking the "E" icon goes away but mobile data still on. After a minutes the icon comes back and data is working.
First of all check if you have any event in Smart Connect that may trigger Google Now when the headset connects.
Is the headset a Sony headset or is it from a 3rd party manufacturer?
I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
You can also try with another SIM card to see if the behavior is related to the SIM/network.
Yes it's a sony headset. The one you get with xperia L.
So I started the fone in safe mode, still google now opens up. I dont use smart connect but still checked the settings, not set google now to open when connect headset.
Tried it with another sim card, google now didnt open( however in this sim mobile data was turned off).
so i tried it with my sim, google now didnt open(mobile data off and on). i dont know if its solved or not but the thing is my headset button doesnt work nor does the mic in it but it works pefectly fine with another phone(MOTO G) the play/pause button and the mic.
tried update service.....still no luck!!
That's strange. Have/could you try with another headset to see if you experience the same behavior?
Tried another headset, still google now opens and the headset play/pause button doesn't work. Whichever headset i connect problem remains the same even when the headsets are working on other phones.
Strange. Try to blow down the 3,5 mm contact to remove any kind of dirty etc to see if you experience any differences. Otherwise I would suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
