wat if battery life is over
rockygreenberet
With non removable battery phones
SONY XPERIA Z ULTRA , XPERIA Z 1 ETC
What to do when battery stops working or battery life is over,is the battery replacable.
Does it effect or hurt the phone,phone data,phone system if non removable battery is removed while replacing.
4 REPLIES 4
Press_Down_shif
Dont worry when the battery life of your phone is over just take it to authorised service centre they will replace it although you have to pay for it after warrenty period...and dont worry your files,data,conatcts and every single file will be safe cos it wont effect the software anyway...and the battery will last 1 -2 years easly even with rogh usage...
1)To take max outta ur battery
*Dont charge it too often try to carge it when below  20% and fully charge it dont interrupt the charge in middle too often
DO NOT SURF NET OR PLAY HEAVY GAMES OR OTHER APPS WHILE charing this will lower your battery life
Pls click KUDOS if u are satisfied with ma reply  gud luck
hykhleif
r u serious that battery might only last 1 to 2 years this is really bad news as this phone is not sold in my country
Sam
Legend
Legend
I would expect it to last a lot longer than that based on what i have seen with our handsets over the years.
What are your thoughts about this forum? Let us know by doing this short survey.
Press_Down_shif
yeah its a Li ion battery and as i mentioned 1-2 years with ROUGH USAGE  if you take proper care you may get better results....
