wallpaper setting for lockscreen and homescreen
Div
I'm not able to set different wallpapers for my home screen and lockscreen.whereas my other friend with same handset is able to do so.We both tried used different lock modes .It is working fine in friend handset even in pattern lock mode .But in my case its not working 5n.
3 REPLIES 3
Alexander1
Can't you find the lock screen option in your phone or doesn't the lock screen background change even though you set the lock screen background under settings > display > lock screen > wall paper?
Have you tried to restart your phone and remove the battery for a while?
If you have the last issue, try to clear data for lock screen and Xperia home under settings > apps > all > lock screen/Xperia home > clear data > restart the phone. Note that your home screen will be reset to standard so you'll need to setup your Widgets again.
Div
The problem  is vth lock screen..after chaging wallpaper for lock screen ,its showing a message that got chaged but actly not getting changed.Same thing even after restarting the device.
ramkumarmrk
Not getting changed, even after clearing data of lock screen and restarting
