Try settings-apps-all-walkman,clear data for both apps.Restart and keep us updated.
I have the same problem. Clearing data and restarting didn't fix it.
Try to clear data for media storage.
That worked. Took a long time to index, but everything finally showed up. Thanks.
Great.
Same problem . Not fixed by clearing Media storage...
I tell you history . Before 16GB sd card I was using 2gb then I removed that 2GB then insert 16GB then problem started...
Please Help me.
Reformat your microSD to FAT32 using a low level format tool.
I tried low level format tool , But still problem is There ... If I reset (factory reset) my all apps & contacts ,msgs will gone or not ??
I also want to tell you , I tride with another music player ..:smileyrolleyes: but it is also not scanning the songs from SD card. In that player there is option for scannig, still its not able to scan.. is thre any protection mode for SD card in Android 4.3 (XPERIA M DUAL) ?
