Walkman crash
Ruker
Walkman crash
when I use Walkman applicaton during Internet browsing, the Walkman crash after about 3-5 minutes. Then I have to go directly to Walkman to start Play button and then the sound will continue. This often repeat during using Chrome.
45 REPLIES 45
do you have any other intrusive app running? taskillers, task managers, antivirus, battery apps, ram apps, booster apps?
Ruker
This happened very early when I bought new mobile so I had no additional application. Now this issue still continue and I have some common applications - no app. which you mentioned.
The issue was on firmware 12.0.A.1.211, continue with firmware 12.0.A.1.257.
that's quite odd, and your music is in your SD card or internal storage?
Ruker
I have music on SD card. But what is interesting is that the issue appears only when I using the Chrome. There is no problem with Walkman in standby mode.
that's quite odd, what if you have the music in the internal storage?
Ruker
So I tried to move the music to internal storege and there is the same issue.
Just one update - the walkman application is still open (I can see it in top panel) but the music doesn´t play. Also the walkman looks as the music is reproduced, because I can see the pause button instead of play button in the application.
try settings > apps > all > walkman > clear everything
Ruker
I tried it but Walkman stop producing the music after about one minute when using Chrome 😞
could it be that you visit certain websites such as youtube or has videos that might stop the walkman app?
