Volume down button after a week of purchase began working intermittently: at one time worked in another does not work.
After 2 weeks, does not work in any application, including the camera. While running at full upgrade, when asked to press a button.
Fully updated - did not help.
Xperia sola. Build 6.0.B.1.576
Dial *#*#7378423#*#* in dialer/ dial pad / phone pad > service tests > keyboard and switch > press Volume Down key again and again and again
Post the results here
Volume Up - Ok.
Volume down key - does not work
Oops, means it's a hardware problem
You will have to go to Sony service center
Before going try this
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Sony Update Service tried to.
will need to contact the service center
